Status
Not open for further replies.
Digital Instrument Cluster
3 reading
65K views 126 replies 69 participants last post by  Darko61
#1 · (Edited)
E46 Digital Instrument Cluster
Let me start off with a small introduction to the new project.
My name is Adriaan, and I am part of ID4Motion. For the people how have never heard from ID4Motion, we are a small team of petrolhead engineers that design and make BMW retrofit gauges cluster. We have made different units for the E81, E90, E60, and more. But many of you were asking for an E46 digital cluster we have started the project.
I hoop to give you guys some insight into this project and love to hear feedback about features and design choices with this tread.
To get a bit of an idea of what we have done with the E90 you can watch a video from Driving Cody or Vehicle Virals
To start: We need a car.
The choice has fallen on this 323i E46 out of 2000 bought from a local dealer here in the Netherlands. Imported from Germany in 2006, with 7 previous owners and 287.254km / 178.491 miles. She isn't the cleanest E46 on the road. The small dents, scratches, and faded paint make her well used. But she is still running strong, perfect for measuring all the signals we need for the digital cluster.
We were searching for a few key options. It had to be automatic, with curse control and infotainment that would be controlled by the steering wheel. This is possibly the most complex electronics configuration available in the E46, covering most of the essential signals.
The fitment into the Dashboard.
We also have purchased a second dashboard and instrument cluster from a BMW scrap yard/wreckers. We use this to measure all the dimensions for a perfect integration and create an original-looking cluster. We are working together with LM Creations, a small concept and design studio in Groningen (the Netherlands), to make a 3D scan of the Dashboard to get a correct fitment,
This 3D scanner has an accuracy of up to 0.02mm:
After the digitalization of the dashboard, we can reverse engineer the mounting brackets for the new LCD. In this case, we use the original mounting point for the BMW e46 cluster for the install. We can also develop a front cover to enclose the LCD screen and give it that factory feels with the digital model. A 3D printer is used to make a prototype to check the fitment into the dashboard.
Over the years, we have developed our hardware on a 10,3-inch or 12,3-inch automotive display. And looking at it, the 10,3-inch display will be the best fit for the E46. This is the same as all the other E Series BMW displays we make. (E81, E90, E60, E63, and more)
(I have to split this post because of all the images 😅)
#2 ·
The next step: Concept art
The next step is creating a concept of its design. Because we are working with a digital screen, we can design a wide range of layouts without any restraints. Critical is to include all the original indicators in the design and have room for multiple data fields to display the Board Computer information.
Theme #1 (You’re looking at the concept art of what might become the default design for the following BMW E46 Digital Instrument Cluster)
This concept takes a minimalistic approach to Skeuomorphism. Skeuomorphism is an embellished UI design style intended to make elements resemble their real-world counterparts. Small details with shadows and highlights emphasize each of the individual indicators and contrast with the minimalistic color scheme and subtle gradients.
Theme 2#
Inspired by the original BMW E46 instrument cluster, The analog gauges with traditional pointers and tick-mark patterns are inspired by the original BMW E46 instrument cluster. The beautiful blue and red color scheme strongly represent the vehicle's brand value and recognition.
Theme 3#
The cluster will have 3 different layouts/themes from the start, so you can switch as you like.
To get an idea of how the cluster would behave, we have made a simulation on the testbench.
We would love to hear your feedback and if you like the idea.
Up next:
  • The internal menu
  • The wiring and connectors
  • Getting the signals
#3 ·
This looks really nice! A few ideas I have right off the bat that would be cool if you could somehow integrate.
1) Manual - shift lights
2) Ibus display - I have the resler ibus interface hooked up to my headunit and use the ibus app with it. One of the screens they have shows horespower along with other standard instrument cluster gauges. Would be cool to be able to replicate on the cluster instead of the headunit.
Looking forward to see where this goes!
#14 ·
Hello guys, let me answer some questions:
  • The is shift lights will be implemented. You will be able to turn on and of the shift lights, and set the Max. RPM, the Red zone, and the Orange zone.
  • Showing torque and horsepower numbers will also be implemented and can be turned on and off.
I want one!
Where do I sign?
We have started a newsletter for some updates, you can sign up here
Very interested for this project. Is it possible to add additional features that are reported over Canbus? Such as boost pressure, AFR, oil temp, current gear, gearbox oil temp, etc?
Yes, this will be the goal. We just started to decode parts of the Canbus, and if it is in there we want to display it.
If there is no Fuel Economy display, I’m interested. I swapped my cluster to M3 just to get rid of that annoying fuel economy indicator. :)
No problem, you will be able to turn on and off the different features.
I guess the whole idea if digital dash is to configure it as you want.
surely there will be an optionthat excludes this.
is there any indication on the pricing yet?
Yes, that is right, the idea is to configure as you want.
Price will be around the same as our e90 cluster, with the base price below 1000.- US dollar and all the features are a bit above the 1K.
Numbers are key in this, if we can buy our components in bigger bulk we can do more with the price. We are hard on the way, but the chip shortage and other components and even the steel prices aren't kind to our production cost. To be clear we build these displays in-house in the Netherlands to an automotive standard, not a Chinees android version.
Interested. I hope there are more themes. Maybe just like the normal analog but with the ability to adjust different colors. Also ability to show canbus info or other info from other monitors would be cool too
First, there will be these 3 versions with color differences and later on, we are looking to implement the analog versions we have from the E90 in the E46
#6 ·
Very nice project. To be honest I really prefer the old school analog instrument cluster, and I wouldn't upgrade my radio (bmw professional cd54) either for the same reason. But I think this looks really cool, congrats on the design.
It would be nice if you could share the technical details about the signals, CAN messages, etc. That could be useful for us.
Is the UI written in Qt/Qml maybe?
BTW on the dashboard you could implement the M track mode for the M3, and the shift lights, etc.
#19 ·
I’m really interested in this, I never even knew this was a thing.
Would be great if you’d be able to include track/radio information on the screen from the radio (not sure if this is possible if you can get them to talk to eachother), much like what many of the modern cars have just where it displays the info. Track/radio change info would be a bonus.
Looking forward to this being launched
#20 ·
I would love this.
Heel goed. ;)
Must haves will be:
  • Economy meter
  • Oil and coolant temp
  • Rev counter with needle (rapidly changing numbers are distracting and not practical IMHO)
Wish list:
  • Current gear indicator for auto boxes in D mode
  • Current track playing & call-info if aftermarket head unit has Canbus integration
  • User selectable info to be displayed in dedicated space (e.g.: date, outside temp, range, Ave. fuel consumption) when pressing BC button on stalk
#22 ·
Are you going to implement all the bus functionality that the IKE is responsible for? For example:
  • Bridging the I/K-Bus with the D-Bus solely for diagnostic requests/responses
  • Reporting Ignition state to the I/K-bus (without this, the dash will not allow cars with OE Navigation to work)
  • Reporting Sensor data to the I/K-Bus (Ambient temperature, speed/RPM (every 2 seconds), coolant temperature, fuel economy 1 & 2, etc)
  • Acknowledging all inputs from the LSZ.
  • Pulling up the I/K-Bus to VSS (less important since there are master backups).
  • Dealing with Redundant data (VIN & mileage information sent from the LSZ to the IKE to trigger the tamper dot)
Thanks!
-Ted
#24 ·
What ever you do, for the love of god, please make sure stability is at the forefront of your production. It doesn't need to have a trillion bells and whistles as long as it runs well and is stable. I want to build a reliable build, and keep the e46 reliable as it was when it was from the factory. I don't want to have to to restart my car half way through every trip because something important stopped working.
#26 ·
I think having it look modern and up to date would be amazing, perhaps having some look a like features from the supra mk5 cluster (which is just a bmw cluster) where if you set it in sport mode it's just one nice big rpm gauge and essential info and lights on the sides of the cluster and then when you go back to drive it switches the display back to the set setting chosen.
i think also having some integration with third party headunits being in sync and sharing data would be super useful! say for example the headunit shares gps data with the cluster and the cluster could display an arrow pointing to the next turn to make, that would make the driving experience that more engaging and interesting. However i do know the complications that might bring when programing it would be a great feature set to have and a very unique one at that!
Would the display also be an oled panel or what kind of technology would be used for this? And would after market ecus integrate properly into this cluster?
I'm really excited for the creation of this and would love to see it come to life and have it sit on my bimmer it would def help it feel like im driving a newer modern car!
Key feature im mostly looking forward is a clean look that's easy to look at and gives all the essentials without being over cluttered or lacking information.
#27 ·
Hi!
I do business at Precision Sport Industries (PSI) [where Vehicle Virals is based].
I've seen one of the units firsthand. I went seeking one for the e46 a good while back, but it didn't yet exist.
I'm excited: It's on the 'must have' list. Do you do pre-release orders?
My comparison (for 'wants') is against my 2015 C7 Corvette Stingray's cluster..
Must haves:
Compatibility with a convertible (the convertible top module doesn't work unless the cluster is in the car, and responding).
Even if not available on initial release, a promise of a software update for future compatibility with a 'vert would do.
Wants / Nice to have:
I/K bus data capture to a SD card (in case say, we don't have the I/K bus messages for a convertible, or parking sensors, or some other feature, we can capture it for you...).
User-configurable display (the 'vette allows you to move the various information bits around so you can do things like water temp on the left, and oil temp on the right of the main display, or the opposite (oil temp on the left, and water on the right).
Oil Temp / Water Temp display on the main screen somewhere (digital/numerical, and/or a 'classic' needle).
Fuel gauge (classic/needle).
Current gear displayed (for ZF/GM based automatic transmissions).
Shift lights (already implemented based on the data in this thread).
Exterior temp on the display somewhere.
Pretty much all of the list from t2ddftw's post.
Shoot for the moon list:
Direct CAN (I/K bus) input (say, from a non-Bosch ECU (DME) for us crazy guys that swap in LS [and other] engines.) Having oil pressure/diff-oil-temp via a mappable CAN message would be stunning.
Where do I sign up for a pre-order / beta-tester / pre-release development version?
Dan B
#30 ·
Two features I have in mind, the first would be a brightness bump up for convertibles on a sunny day.
the second is a long shot, but would it be possible to integrate an OBD2 reader into the display? Maybe get a license from icarsoft. The type of people who will buy this are probably DIYers, and having that capability would be huge
Status
You have insufficient privileges to reply here.
