21 - 40 of 49 Posts
Currently its not implemented. We´re still behind what we wanted to have achieved by now, so its basically a matter of time until LC works like expected.
Hey daniel first I want to say thank you for everything you done allowing us to be able to tune our e46s... I just have one question has Launch Hysteresis parameter been implemented yet?
Can any help me with Launch Control
I have m54b30 engine from e46 330ci I swap in e36
I flesh full file from Daniel and don't work , I don't have clutch switch so I make button simple to try with 2 wires , one wires in pin 23 and other in negative of battery but don't work , clutch switch in inpa work when I press and depress
This evening I tried to make launch control to my ms43. Following the steps from wiki. I downloaded the logger for my engine load it in tuner pro also load the xdf. Made the following tables. Made full write with ms4x Flasher. The car started with the new verison but LC DOESNT work I think I am doing everyting as it is writen. Is there something more to do?
I'd love to help - but I'm having my own issue. But, doesn't your DME say it's MS41 and not MS43?
Little update. Tried with the brake switch... Still the same... Rpm goes to 6500... I am wondering if the made maps are correct.
I ended up using the exact same bin (MS430056, M54B25, EWS delete, and Launch control, right?) and launch control isn't working for me. I didn't modify any of the launch control values, from the bin though (I assumed they were already set properly).
I dont think that they are set. Try to make it as the picture in the wiki or like my maps.
21 - 40 of 49 Posts
