Here´s an instruction on how to configure Launch Control (LC) at MS43 and use them:
1. Download the corresponding files in the google drive within the folder "Launch Control". Choose the one that matches your engine displacement. Also download xdf with LC in the description.
2. Flash the file with JMG
3. LC is preconfigured in TunerPro to have a bit of security. If you feel you need to tweak the settings download the tune with Galletto and open it in TunerPro.
4. Under "Special Functions: Launch Control" you can tweak the shown values. Description is available by hovering the mouse over each setting.
5. Save the bin and upload it using Galletto
Using LC
1. Make shure coolant temp is equal or above the treshold
2. Depress the clutch pedal
3. Choose first gear
4. Floor the accelerator pedal! (At least that °PVS matches the treshold!)
5. Engine speed should bounce at choosen rpm setpoint. There may be offset which engine speed bounces, like +/- 200rpm
6. Release clutch pedal while holding accelerator pedal down.
7. Engine speed will be reduced until vehicle speed exceeds choosen treshold
This feature, LC, won´t make you a professional driver and it won´t make your car a sports car! If the settings are tweaked to your cars drivetrain and your skills it can definately enhance your cars performance.
Warning:
If the engine does continue to increase rpm even with tweaked settings, you have one of very few weired DME´s that we need to investigate further!
Check youtube for reference how its intended to work!
Development of LC is still going on so check back for the latest updates available!
Using LC
Warning:
