speedometer accuracy.
29K views 72 replies 41 participants last post by  Luck7
#1 ·
I noticed last night when I was driving my car's speedometer was at 65 MPH with cruise on but my Garmin GPS (portable) was showing 62 and 63 from time to time (even on flat roads).
Which could be correct? should I be concerned? Any way to verify this otherwise?
#3 ·
Nothing to be concerned about...completely normal.
Whether gov't conspriacy or the size of your wheels, there's a speed sensor that, from what I know, assumes a specific size of tire...so changes in that will affect accuracy (correct me if I'm wrong, folks). If you get a gps fix on long straight away, trust the gps. I know mine is off like 50' (don't know if THAT is normal), but on a long run, think gps is better.
I just saw the inside of the front wheel bearing, don't know if it's there on every bearing...probably...a flat ring of magnets...behind a plastic 'washer'...anyway, it sends pulses to the sensor behind, so speed is calculated based on the speed of that thing spinning and it assumes a diameter of tire to give you speed.
But, I've heard that every speedo is off to the low side anyway...to fool us into thinking we're going faster than we really are. Larger wheel/tires might correct that so you're accurate, but then you'd also be slower...so you got to chose!
Doug
#7 · (Edited)
So that's what they were!
You know, Chas, when I said someone could correct me, I really didn't mean that! LOL
But, I guess the principal would be the same...around a fixed moving object, so when tires are larger, you'd have greater accuracy but slower speed...per the discussion recently on tire size/rotating/unsprung weight and where the weight is on the wheel.
Someone can correct me again if needed!
Doug
#6 ·
For some reason this is somewhat a common issue with most German auto makers. Most of the time the speedometer reads too high a speed.
As I recall, my E46 reads about 3-4 MPH too fast?
You should also check to see if your odometer is reading correctly, using both the GPS and highway mile markers.
My wife had a 2003 VW Beetle and the speedometer would read about 5-6 MPH to high at highway speeds, however, the odometer was dead on. As I recall, VW claimed that if the speedometer was within 10% then that was considered normal.
My GMC Yukon is dead on for both speed and odometer as compared to my GPS.
I would believe a GPS long before I would believe a German speedometer!
#8 ·
My bmw is right on with my gps. I've had 2 ford escapes for company vehicles and they have both read 3-4 mph high at highway speeds. I thought american manu's did this intentionally as a form of speed control. The same with sportbikes, they always read high to make the driver think he's moving faster than he actually is.
#11 · (Edited)
Yes, tire sizes make a difference. Tread wear make a difference too, cause a new snow tire will have a larger circumference than a bald summer tire.
use this to check differences between tire sizes on a basic level:
http://www.miata.net/garage/tirecalc.html
I upgraded my tires and used BMW specified sizes (244/40/17 to 255/35/18) and knew that my new tires would leave my spedo 1.3% slow, so when the spedo said 60mph I was actually going 60.8 :read:
Weather BMW builds in a margin, I dont know. GPS can be pretty accurate though. My jet-ski has gps :D
#12 ·
This is a built-in safety. In several european countries the law states that the speedo can read more but Never less. So it's built into the system this way. BMW speedos are made to read optimistic some 3%.
#68 ·
This. Actually, the speedo can never read too slow, regardless of the wheel/tire option that could be fitted to a vehicle (without modification). But the car knows how far it has travelled. My VW had the sam issue.
#16 ·
every one i have had has read high compared to the portable radar units the cops set up. i used to follow the new car reviews closely and noted that the speedometers usually read a bit high. maybe a car manufacturer would consider it a liability to report lower than actual speed. somebody somewhere would try to sue them for a speeding ticket or wreck. so i figured they would bump it up a little to be safe.
#25 · (Edited)
Well i really should have searched - there's a ton of info out there, it seems pretty much all E46 have this problem and it's "normal" and that's with OEM wheel size, just like mine. Last night I checked it again, and it's only 1-2 mph off, not 2-3 like i thought earlier...a bit annoying, but guess better than other way around. All my other cars have been dead exact with GPS. must be a euro car thing, from what I read.
I guess I shouldn't depend much on the "range" or miles left indicator, either then...
#27 ·
My thoughts about speedometer inaccuracy
Just returning after a long absence on this forum...
Did anyone also realize that this speedometer inaccuracy also affects the odometer?
Just a 5% error can add about +500 bogus miles a year (assuming 10k/yr) to your odometer, thus lowering the value of your car... and if bought new, caused the warranty to lapse quicker.
Just saying...
#28 ·
Just saying...
As stated before it is only on the needle. The ecu has the exact speed (as long as you dont have a drastically diffrerent OD on your tire.
#31 ·
My partner is always telling my to slow down on some of the heavily patrolled roads... and I keep replying "but the speedo is off!"
Why can't the needle just point to the actual speed??
Compensate with different sized rear tires. I replaced my 245's with 255's and my speed is spot on to my Garmin.
#32 ·
Hi. The only vehicle with a true speedo reading is a vehicle with a speedometer that has been calibrated. I drive a passenger coach and it has to go on a rolling road every two years for calibration. When I have my satnav on it shows the same speed as my speedo. Jim
#73 ·
Hi TerraPhantm,
I know this is an old thread, but I'll try my luck.
I'm currently running 19" M3 wheels on my 323i. My odometer used to be 4Km/h above GPS speed, but now it's actually showing 97Km/h when I'm driving 100Km/h on GPS.
You mentioned changing some settings in the Cluster to fix this. Would you be so kind to tell me which values have to be changed exactly?
Thanks!
#34 ·
Speedometer accuracy
My 2002 330CI is the first car I have had where the speedo reads exactly the same as my Tom Tom. I've tried it in quite a few cars and the Tom Tom always says I am travelling slower than the speedo -typically 65mph at an indicated 70mph.I had decided that the Tom Tom was probaly wrong but the 330 speed ties up with the rev counter mph/1000 revs so I guess its right - I doubt it the speedo, rev counter and Tom Tom would all be wrong?
