Hi all,
I get this sporadic P1350 misfire on cyl 5, and try to track it down. Last time I smoke tested everything checked out. Pre-cat O2s are about a year old, as well as the MAF (both from FCPeuro).
I attached the freeze frame from the P1350 error (see PDF).
Last days I checked my coils and spark plugs to see how they look, please let me know what you think based on the pics.
There's white greyish residue at the top of almost all the coils (not only the 5th), see pics. The greyish substance can be rubbed off more or less, and creeps out from both sides of the black band that's around each coil top. Around some of these greyish areas there's also some kind of rainbow colored discoloration, like when gas swims on water. See here multiple coils.
Edit: Are these the coils from the (ancient) recall that I just read about? Bremi manuf. date xx 2000.
There's also on 2 or 3 coils an oval shaped mark on the boot. Any idea if that's normal? (see red circle on boot).
My coils are original, manufacture date: year 2000; about 250k miles.
My plugs are about 2y old and less than 20k miles. I know those are not the recommended plugs for the car, but from my understanding back then they should work just fine, and they seem(ed) to do!?. But let me know if you think my problem could come from those plugs. I don't have oil in the wells, not 100% sure where the oil on the threads comes from.
Cheers,
-fana
Cheers,
-fana
