I purchased a 2002 325i 5-speed with 120,000 miles in May. Everything on it worked just fine. But it is a 15-year-old BMW, so I have replaced nearly every part that could go bad in the foreseeable future (coolant system, gaskets... *see below for full list).
I have had trouble bleeding the cooling system using the standard posted steps (all the common variations). Here are some of the observations I have made:
1. The standard methods of bleeding may work for some people, but they did not work for me. I kept getting the "no heat through the vent" and coolant temperature climbing rapidly into the 120C (248F) range. I followed the multiple variations of instructions to a T. I repeated checking the coolant system daily for more than a week to further bleed the system, burp the hoses, raise the front end, to no avail.
2. I used Airlift cooling system refiller after draining the coolant, Instantly, the heater worked well, and I have not seen the coolant temperature go above 98C (208.4F). Most of the times, the coolant stays at 97C maximum, dipping into low 90s occasionally.
3. In the photo are some of the parts I have taken out of my car and replaced as preventive measure. This allowed me to better study the general topography of the coolant system.
4. The heater control valve is by default "open." That is to say, coolant can flow through freely when no voltage is applied to the solenoid. So the questions is, why does virtually every "instruction" out there state that the key must be turned and the heater must be on 91F and fan low? The heater control valve is open without even putting the key into the ignition. Therefore, one does not need to put the key in the ignition to bleed the coolant.
5. This BMW does not have an auxiliary coolant pump, just a heater control valve. So the notion that the coolant will circulate through the system (heater core, etc) by turning the heat up (when the engine is off) is incorrect.
6. The bleed screw appears to be the highest point of the cooling system. However, that does not necessarily mean that all (or most) of the air will bubble out of the bleed screw just from rising through the system. There are probably 3 reasons for this:
6-A: First, there are local "upside down U's" in the system, such as the pipes that come out of the heater core, where air can be trapped locally, causing "air lock."
6-B: Second, coolant has some surface tension, whereas air bubbles are much more likely to follow the path of elevation in fluids with less surface tension such as alcohol or acetone.
6-C: Third, coolant is attracted to the inner surface of the coolant system to varying degrees, forming a meniscus, which may make air pockets more difficult to dislodge.
7. Even when the thermostat opens and the water pump directs the coolant throughout the system, there are pockets of air (air lock) which partially or fully block passage of coolant through parts of the system. It is easy to underestimate the effects of air lock preventing partial or any flow.
8. Coolant does not move as fully formed "pistons" through the cross sections of the coolant system. Air pockets may occupy the top half of the cross section, dramatically reducing the flow through that part of the system. Coolant flow will follow the path of least resistance. The system has places which behave like "parallel circuits," meaning virtually no flow goes through partially obstructed pathways.
9. Even in the best of circumstances, it is not possible to fully eliminate all pockets of air, for instance, in the head. (This is based on experiments done by people who have observed air pockets in non-BMW heads using Plexiglas plates.) My conjecture is that much of the problems of BMW cooling system can be attributed to local pockets of air, let's say in the exhaust side of the head, which prevent adequate cooling, leading to, for example, cracked heads.
10. The expansion tank is much maligned as the cause of the coolant system failure. However, the exact sequence of events is not always clear. Does the crack in the expansion tank cause loss of coolant and runaway temperature leading to engine overheating? Or does local overheating in the head cause "departure from nucleate boiling" leading to pressure spikes that rupture the expansion tank? This remains an open question without further experiments to validate.
11. My BMW "likes" to run at 97C (206.6F). In contrast, my 2010 Honda Accord 4-cylinder "likes" to run at 83C (181.4F). My wife's 2014 Toyota Camry 4-cylinder "likes" to run at 85C (185F). The practical significance of this on whether BMWs have a more "problematic" cooling system is not clear.
12. Ideally, the way to observe where air pockets really collect, and how easy or hard it is to bleed the system using various methods, would require an experiment where the entire cooling system is replicated in clear see-through plastic, then drive the water pump with a 10-horsepower electric motor, and observe the flow of the coolant. It would be an approximation of what is happening in the cooling system under normal conditions.
13. The rise in the pressure of the coolant system has 3 components: Expansion of the coolant liquid (by perhaps 4 ounces from room temperature to operating temperature), vapor pressure of the coolant, and the expansion of the air in the system. From this, one can probably conclude that there should be at least 4 ounces of "head room" in the coolant system that is air/vapor and not liquid, as expanding liquid not accommodated by bulging hoses will likely result in something bursting or the coolant spewing out. (The cap has a blow-off pressure valve, but it does not always work perfectly.) When people fill up the expansion tank to the top of the rim, the "head room" probably exists in the form of air pockets hidden in the system and/or in compliant hoses.
14. Even though my own solution to the "coolant bleeding problem" was to use the vacuum bleeding system, there are reports that the vacuum itself sucks in rubber seals in the radiator, causing leaks. So even this is not a panacea for all situations.
In conclusion, my own experiences and thought experiments lead me to surmise that the "coolant bleeding problem" is not always a simple matter of following printed directions. The system remains a "black box" with unknown amounts and locations of air pockets.
(*Full list of items I have replaced as part of preventive maintenance:
water pump, thermostat, all the coolant hoses including heater hoses and hard plastic pipes, VANOS seals, valve cover, valve cover gaskets, battery, oil filter housing gasket, belts, pulleys, tensioners, radiator, expansion tank, headlight lenses, coolant temp sensor, coolant level sensor, "radiator cap," DISA valve, oil pan gasket, front control arms, front control arm bushings, tie rods, front struts, rear shocks, RTABs, fuel pump, fuel filter, vacuum lines, spark plugs, ignition coils, starter, alternator, tires, rims, HVAC "resistor", headliner, pillar covers, cup holder, arm rest, driver side front window regulator, all the mirrors, brake pads, transmission fluid, differential fluid, intake boots, VANOS oil pipe.)
