Hey All,
I want to attack this. I've read a few diy's/etc and I've seen mention that the intake needs to be removed to remove the plastic coolant pipe (I just replaced about 10 months ago) and I wanted to check in here to see if this is for sure needed or if the front timing cover can be removed by just dropping the oil sump in place, removing the crank shaft pulley, the valve cover and then the bolts holding the timing cover on.
thanks in advance!
thanks in advance!
