K-Line cable to DCAN cable? Mod?
1 reading
5.6K views 8 replies 2 participants last post by  Bali
#1 ·
Hello people,
I own a USB-cable for my BMW E46 year 2002, everything works fine so far incl. INPA & Co.
I will call this "Gen 1" cable in the following (because I do not know the most accurate name as everybody seems to call it differently).
Now I thought give it a try to modify the cable so that it works for the E92 year 2012.
What I found out:
My current "old" cable has PIN 7 and 8 permanently connected (soldered).
The newer BMW DCAN USB cables (I'll call this "Gen 2" cable below) seem to have PIN 7 and 8 open. I know this because there is a manual how to install a switch to make the Gen 2 cable suitable for older vehicles by connecting PIN 7 & 8 with a switch.
The question I ask myself:
Why can't it be done the other way around? I have opened my Gen 1 cable and desoldered PIN 7 and 8. Unfortunately INPA still does not recognize the E92 ... Why, where is the difference? Is the board different so that the Gen 2 cable is backward compatible but the Gen 1 cable is not forward compatible?
Thanks in advance
#3 ·
No I verified by looking at the solder..
previously the PINs of my Gen1 K-line cable were connected like this:
After desoldering like this:
But I found out that probably the Gen 2 cables (called K+DCan) do actually support both using a PIN7/8 switch. But the old cable (Gen 1 / K-Line) I feel simply is not ready for newer cars - probably some electronics missing on the board.
#4 ·
Check if pins 7 and 8 are still connected using a multimeter.
In post #1 of my software install thread, I always recommend people buy a K+DCAN cable with built-in switch to easily use on older and newer BMWs.
K+DCAN cable with a switch, for example: Amazon.com: K+DCAN Cable with Switch
I have never tried the older K-Line cable (with pin 8 disconnected) on newer generation BMWs such as E9x, but I would expect it to work fine.
