I want to install a leaf connector in a spare fuse location so I can hardwire a shock sensor. How the hell do I remove the fuse box? I don't understand these instructions.
Status
Not open for further replies.
How do I remove the fuse box in the glove compartment?
Twist the 2 white tabs to release the fusebox, it will drop enough to allow you to slide from behind the fuse leaf connector, done it multiple times for my shock sensor, power seats, folding mirrors, aux stuff etc.
"When trying to gain acces to fuse locations #65 and #70 there was no wa in hell I could gain access to the because of the stock wiring harness being in the way (I you added stuff to the fuse panel you know what I'm talkng about) I had to remove 3 torx screws under the fuse panel and then the ~ 13 8 mm hex socket bolts i order to remove the fuse assembly from the panel itself."
You can get in without removing the screws, but it is a pain. Remember to slide the blue tab to “unlock” the holes for the sockets
Status
You have insufficient privileges to reply here.
Related Threads
E46 Fanatics Forum
posts
18M
members
613K
Since
2001
A forum community dedicated to BMW E46, E90, and F30 owners and enthusiasts. Come join the discussion about M performance, turbo kits, engine swaps, builds, modifications, classifieds, troubleshooting, maintenance, and more!
