Edit: FIXED -- Few years and I wanted to update my fix... i removed the hoses to make sure there were no clogs. One hose going into the canister had a TON of the little charcoal pebbles that looked like it was blocking the airway. (Maybe it is supposed to be that way)?
Anyways.. I went ahead and let them fall into a cup and made an airway going into the canister. So far I have had no issues.
GL to anyone else maybe searching around finds this thread.
Hi all, I've done a lot of a research of this topic since I am tired of taking 10 minutes to fill my car up.. I looked under the wheel well near the fuel tank where all the lines run and don't see anything that looks concerning.
I replaced the fuel tank breather and found no change. I have also tried position the nozzle at different angles as I can read that has worked.
What would your next step be? Could this be my fuel pressure?
Sent from my VS995 using E46Fanatics mobile app
