Thread covering F20/21/F30/M140i Brembo brake conversion on my E46 using F20/21 4pot front & 2pot rear Brembo calipers and Genuine BMW size 340mm front & 345mm rear discs.
FRONT 340mm Brembo reference number 09.C397.13
REAR 345mm Brembo reference number 09.C396.13
The rear brake conversion I have detailed will not fit a 330/ Clubsport/ M3 or any BMW that uses a 180mm internal handbrake size!
160mm handbrake size only for this one! E46 323/325/328 maybe more.
I have just completed the F series 345mm rear brake conversion on my supercharged 325ci.
Using the Bmw F20/F30 rear brake disc 160mm internal handbrake 345x24mm disc and the 2 pot Brembo caliper with 40mm pistons.
Dust shield needs cutting down to the handbrake shoes (160mm) and then the disc will sit perfectly on the hub, handbrake engagement is perfect and original securing screw can be used.
Lugs on the trailing arm need drilling out to 10.7mm and tap to M12x1.5 to secure the bracket/caliper assembly. You could nut and bolt it using the original M10 bolts but not easy to access the nuts to fit or remove the caliper.
Caliper will require a bracket making but it's a relatively simple bracket to make as it's flat. I opted for an 8mm steel plate.
Caliper needs modifying which again can be done relatively easy.
I had them milled but I'm sure it could be DIY done with time and patience depending on how you want the end result to look. I also painted the machined out parts with BMW B45 estroil blue. Perfect colour match 👍
Hel brake lines make brake lines for the M3 to F8x caliper conversion which works perfectly for this as it's essentially the same thing.
Will only fit models with 160mm handbrake so no 330/clubsport or M3 fitment.
More can be found on my Instagram: E46_Supercharged
