This is not an active question, but one I meant to ask last week.
When I was doing my parking brake adjust, at one point, I decided to try removing the rotor. I eventually adjusted the parking brake with the wheels fully installed. But at one point, I resorted to trying to remove the rotor to see the sprocket.
Passenger rear. I removed the 2 caliper bolts, and removed the pad wear sensor. But, the brake fluid line had almost no play. I was not able to pull back the caliper far enough to clear the rotor.
Is there a trick to removing the caliper?
