Advice needed on Oil Sump Sealing: BMW Drei Bond vs Versachem Sealants
8.7K views 5 replies 5 participants last post by  paraklas
#1 ·
Doing the oil sump gasket this week and checking the procedures.
TIS says:
Sealing surfaces clean and free of seal debris.
Apply a bead of Drei Bond 1209 sealant (refer to BMW Parts Department) approx. 3 mm wide and 2 mm deep in area of parting joints.
https://www.newtis.info/tisv2/a/en/e46-330ci-cou/repair-manuals/11-engine/11-13-oil-sump/BEDIwAG
The above is out of stock and must be ordered and costs $25 for 50g tube. I am wondering whether I can use the following product in the same manner:
#4 · (Edited)
My understanding is that the Drei Bond 1209 is a 'pliable non-hardening" sealant. Black rtv is pretty squishy when cured so what you have should work fine.
Fwiw, Versachem has a Type 2 Gasket Sealant that is labeled as such and I think may be closer to the Drei Bond:
https://www.amazon.com/Versachem-23009-Type-2-Gasket-Sealant/dp/B0002JN59C
I couldn't find Hylomar easily, but the versachem type 2 was cheap and available. Have used it successfully on two oil pans, two valve covers, and on the Vanos gasket between the timing cover & Vanos itself.
Loctite has a something similar:
https://www.amazon.com/Loctite-Gask..._3?s=automotive&ie=UTF8&qid=1528100508&sr=1-3&keywords=loctite+gasket+sealant+2
#5 ·
Permatex Ultra Black is what I have used on a number of VW gasketless oil pans and also on the 1/2 moon area of the BMW valve cover gaskets.
I find that Ultra Black is best to allow it to skin/firm up for around 30 minutes or what is in the instructions before final torquing.
Seems like Versachem may be similar to Permatex Ultra Black. Who knows if Permatex is a rebranded product over seas??
https://www.amazon.com/Permatex-821...002UEN1U/ref=sr_1_3?ie=UTF8&qid=1528113731&sr=8-3&keywords=permatex+ultra+black
