My engine is still disappearing large-ish quantities of oil! I rebuilt the head, with new Viton guide seals, the crank-case breather and all of its hoses and tubes are new. New oil filter block and valve cover gaskets. NO coolant in the oil, NO oil in the coolant. NONE of this has made on but of difference to the oil consumption!
Performance is great, compression is amazing, considering the 225K miles - over 200 PSI on all six cylinders! There are NO leaks! I can drive the car, then park it on a large piece of clean cardboard. Next morning, not a single drop of ANYTHING anywhere on the cardboard.
Yet it has disappeared 2 quarts of oil within the last few weeks! HOW? By what path? In the next few days I'll pull the plugs, and look for evidence of burning, but if it is, how is it getting in there? I can't imagine the compression being so high if there is any problem with the rings, yet I can't see anywhere else it can be coming from....
What's really amazing is it seems to go a long time barely using any oil, then suddenly disappears a quart or more in no time at all. It has been consistently about 1/2 quart low for weeks. Then in just the last few days, maybe 200 miles if that, it suddenly drops to nearly two quarts low!
Regards,
Ray L.
Regards,
Ray L.
