Hello BMW Experts!
The hole in the hub which takes the lower bolt for the shock is almost stripped. If I take off the washer by the bolt head (making the bolt go in further), I can get a little grip (maybe 40ft/lb instead of recommended 75 + locktite).
Unfortunately, a through bolt goes through but the nut might not snug up against the hub hole because of the angle it emerges at. Can/should this hole have an insert put in (heli-arc?). :hmm:
Murf :woot:
Murf :woot:
