Vmr wheel offset Q
3 reading
3.4K views 23 replies 5 participants last post by  Pole position
#1 · (Edited)
So I just cracked one of my OEM wheels, giving me an excuse to get some VMR 718's. I plan on running 8.5x18" all the way around on 255 Bridgestone s04's. What offset should I get to fill my fenders nicely? Had 15mm front spacers and 10mm rear spacers on previously with my 8/8.5 staggered OEM set and was hoping I won't have to use them with the new wheels. Also what bmw center caps fit these rims. Thanks
#2 ·
Your OEM caps will fit these wheels.
What style wheels did you have? What were their specs? If you want to try to match them, just do some quick math...
For example, if your OEM is 18x8.5 et37, and you had a 10mm spacer out back... then effectively they were 18x8.5 et27. Check with VMR and see if they have a well with the specs that match what you were running.
#23 ·
Depending on how bad your rubbing just take a dremel tool to the inner fender where your making contact to take a drill with a wire brush and take it inside the fender lip and get all the rubber out then tap on the inner lip with a rubber mallet that'll give you a bit more room
