I got all the 4 inner bolts and 11 perimeter bolts off. The valve cover is on rock solid. I tried hitting it with a rubber mallet. That did nothing. It feels like it's cemented on, there is not even a hint of looseness. Is there a certain technique I can use? Do I pry with a screwdriver, or will that crack? I've tried grabbing around the perimeter and it's not budging.
Also, while I was taking off the coil packs, I tried to reinstall one, and was unable to. I would press it back down, but it would sort of spring back up. It would not firmly seat, and instead bounce back out of the hole. Is there a trick?
Steps:
1) Remove Cowl
2) Remove Engine Cover
3) Unclip coils and remove
4) Move O2 wires
5) Remove 4 inner bolts and 11 perimeter bolts
6) Remove cover
7)
Steps:
1) Remove Cowl
4) Move O2 wires
6) Remove cover
7)
