First off, I have a '02 330xi with 94k miles.
For a few weeks now my steering wheel will catch/ grab/ stick for a
moment when I turn. It quickly smooths out again and is not an issue
when driving straight.
Sometimes it makes a squeaky rubber, rubbing noise too.
Its sometimes scary and my wife won't drive my car any more...
I've been researching online and ended up getting the power steering
pump replaced and put a new reservoir in as well.
That did absolutely nothing to help the issue. So, I just spent $350
on not fixing the issue (but hopefully, preventive maintenacne).
I am not rich and can't take the car to a shop again.
I've check the tie rod boots for holes or fluid in them and they seem
fine. I'm not losing any ATF fluid from the reservoir either. So I
hope the issue is not the rack.
I've jacked the car up and shook the wheels up and down to test the
looseness of the tie rods and the wheel is firm in place.
The FCABs were replaced about a year ago but not the whole control arm.
Finally I sprayed WD-40 on the two U-joints that connect the steering
column to the rack. I don't know if was a placebo but it felt great
for a day.
Would the "steering guibo" or bearings in the U-joints cause this?
Is there anyway to check this intermediate shaft without taking it out
of the car?
I appreciate any help on this!
for a day.
of the car?
