Set on a Pioneer setup. Which ones? (For E30, but figured you guys could help.)
5.6K views 20 replies 8 participants last post by  StereoInstaller1
#1 ·
First and foremost, I know jack crap about aftermarket sound systems. I'm not an audiophile, so as long as I get a decent sound, I'll be more than happy.
I've already decided to go with Pioneer's A-Series 5-way 6"x9" speakers for the rear (some cutting required) and definitely want to keep the 5.25" size up front. My question, though, is which 5.25" speakers should I go with?
I think I want to keep it in the A-Series range, so I'm looking at the following two:
TS-A1305C - 5.25" component speakers with separate tweeters.
TS-A1375R - 3-way 5.25" speakers.
I was considering the 3-way speakers so I don't have to bother mounting tweeters. That and they're a bit cheaper. :dunno:
I was told to run a 750W amp to boost everything up a bit and really bring out the 6"x9"s bass (which I'm not looking for a ton of bass; about 15-20% more than what my E46 had). I'm not sure what kind of amp I'd like to run, but I was told it needs to be a 4-channel. Does it need to be bridgeable?
Any and all help is appreciated.
#5 ·
In general, you'll get much better performance/$ with speakers that aren't explicitly made for car use. On the rear shelf, I would put only subwoofers. If you're willing to cut and can make them fit, put a pair of Tang Band W6-1139sif woofers in the rear deck. The W5-1138SM, though 5.25in, is far worse in performance, though much better than any other 5.25 for bass.
In the front kick panels, put a pair of DC130-4 woofers.
For sail-panel tweeters, see if you can fit any of:
If you're willing to put a midrange up high in the door (such as the FR58EX or BMR12), then you can put actual tweeters in the sail panel and cross them much higher.
Real tweeters include:
If you need help with any of this, please let us know. I have no idea what, if any, fab skills you have, but the fact that you're trying to make a race car streetable tells me you're reasonably capable.
#8 ·
I would put it in the trunk, and for the most part stay stock size with speakers. It will save you a lot of trouble. But also remember, if you get a sub you need an amp, and those alone will run $200+. Pioneer makes really good head units as well, I have one in my e46 with bluetooth. It was $130 I believe.
Back in my e36 I had 2 pioneer 6x9 4-ways in the rear, 2 4 inch pioneers up front, and 2 Kenwood 12's in the back powered by a 2000 Watt Planet Audio amp. (never putting that much weight in the back again, it was a 318iS.)
#12 ·
So, you're not going to fit anything good, even from Pioneer, in the back without some extra height.
Look at http://www.midwestroads.com/bmw/#speakers. This is a private seller parting out an E30, and he's selling the premium speaker package. This is what my brother's E30 had, and I was honestly completely blown away by how fantastic that sounded. He's missing parts for the front, so you may as well get Pioneer there, but the reason these fit is because of the extra space provided by the mounting frames/platforms that he's selling with them.
#13 ·
If you're willing to cut, though, the Tang Band 5.25 subwoofer is a fantastic way to go in the back. That way you don't lose any trunk space to the sub. Also, if you do put a sub in the trunk, it needs to be very loud because there's a lot of sound insulation between the trunk and cabin. A friend of mine used to have a different E30, and his sub was much louder outside the car than in.
If you do go with the TB Subs, add one of these in series with each side.
#14 ·
Trust me on this: A lot of sound deadening material has been removed from this car. It was in the works to becoming a race car, so I'm working on getting that restored. My original plan was to run 6"x9"s in the rear deck, but I'm not sure how well that would work out for me. Some cutting required, yes, but I'm sure they'd fit just fine. As far as enclosing the backs of them, that would be an entirely different challenge.
I'll have to do more research before I dive into it.
#17 ·
Oh man...first, let me ask: why Pioneer? They make fine decks, one of my faves in fact...but for the rest of it Pioneer is not the best choice either for price or performance.
Have you read the "Killer $500 Stereo" thread on R3V?
BTW, there are trunk springs running across the rear deck, under the sheet metal. Getting anything to fit flush is going to be just about impossible.
Luke
#20 ·
I have a 318is. Well the Luke Box fit? If so, go with 5.25" speakers all around and install the single 10" sub in the Luke Box?
I was hoping to keep it around $300. Money is fairly tight and I'm no audiophile, so I just wanted something decent so I can at least enjoy music.
[Sent from my Galaxy Nexus.]
#21 ·
Absolutely. It will drop in and you get audiophile quality, like it or not: big, deep, clean, loud, solid thump with no rattles. Flawless fit, extremely tight, plenty of trunk left. So well designed it actually makes your car quieter, these truly are unique.
However, it would kind of break your budget. The box alone, shipped to you, is going to be over $250. A $50 woofer and a $50 amp still needs $40 in cables to install and a $150 5 channel amp makes way more sense in terms of money spent. You are better off doing a 5 channel with stock speakers than anything on deck power, it makes a huge difference.
I know you are on a student budget, but you can only stretch a dollar so far!
let me know if I can help.
