Rhythmic Ticking Noise from Wheels
1 reading
6.9K views 10 replies 5 participants last post by  Dahmwern
#1 · (Edited)
SOLVED: See posts below.
Hey guys,
Did a ton of searching on this but not very many threads were followed up. The story is this: Whether I am driving normally or coasting in neutral with the engine OFF, I can hear a rhythmic ticking noise coming from the wheels only when the windows are rolled down and the noise has a curb or building to bounce off of. Its not loud enough to hear in the cabin.
Its not a grinding noise, just a quick rhythm tick tick tick tick tick that speeds up with the speed of my car. Like I said before, doesn't occur with the engine on so its not engine related.
Points of interest:
- Just lowered my car a bit recently (no ticking after lowering)
- Just installed wheel spacers, 15mm all around, (might have been ticking after this)
- Just installed new Hankook Ventus V12 tires
I have about 93,000 miles on my car, that is a 2005 325xi.
Possible solutions I've read:
- Wheel bearings: Could be, its getting close to that time, but the other stuff I've installed recently can't be a coincidence
- Lug bolts hitting e-brake cover: Plausible, but really?
- Dust shield hitting something behind brakes?
- Anything else?
I need to track this down.
Thanks.
#3 ·
Bump
#5 · (Edited)
Yeah pretty sure it has to do with the spacers/extended lugs. You either need shorter, or need to re-torque.
I have had this problem myself
edit: a small rock stuck in your tire can make a similar noise! serious... lol
#7 ·
Lol, thanks for the input guys. Can people shed some more light on the wheel bearing noise? I can't believe that from one day to the next it would go from dead silence while driving to an annoying it. I feel like it would be more and more gradual. Since the tick started, it hasn't gotten any worse and its been a few weeks of daily driving.
Any idea if that would rule out wheel bearing issues almost completely?
The only problem I'm having with the lug bolt length solution is that I got them in a set, all the bolts were the same length. Do you think I just torqued one or two down too much and now they rub a little bit?
#8 ·
Take a high speed curve like highway entrance ramp. If it's bearings, you'll hear the ticking louder (usually) on the loaded side. So the left side bearing if it's a right turn.
It's hard to tell if it's the front or rear, too, so be careful in assuming where it might be coming from.
#9 ·
That's interesting that you say that. I've taken some high speed on-ramp curves now that I have coilovers and good tires. Seriously, I can go 60 around those and the tires aren't squealing yet. Its insane.
Anyways, back on topic, I'll try it out with the windows open but the problem is that the sound is faint so if its got nothing to bounce off of I won't hear it. On-ramps usually don't have curbs so I doubt I'll hear anything.
Nevertheless, I'll try.
#10 ·
Bumperdump.
#11 ·
So here's a funny conclusion to how this was solved...
I finally took my car to the shop since it was very cold today and I wanted this problem solved before it got too cold and snowy to have to worry about it, and other things that may happen. Long story short, my indy shop called me today and told me they found the issue that plagued my car:
Rocks stuck in the tire tread.
I read that solution and dismissed it before, but I'm posting this to warn others that have had this problem or may have it in the future. Get those damn rocks out of your tread before you proceed!
At least it gave me a chance to get my brake and power steering fluid flushed.
