Review of the A-1 Cardone Remanufactured Brake Booster
6.3K views 9 replies 6 participants last post by  gryphon3579
#1 ·
So after installing a bad junkyard booster into the car, I got to perform the joyous task of doing it all over again, this time I decided to buy a remanufactured unit. I ended up buying the A-1 unit from Rockauto for 99 dollars with a 51 core charge and upon receiving it I noticed that the finish is different, it has a textured silver finish.
Here are some pictures from Summit's catalog which also sell the A-1 rebuild.
In order to perform the DIY I followed 50sKid's excellent DIY on youtube which I had to modify a bit for a manual car, which mainly consisted of plugging the braided hose for the clutch.
https://www.youtube.com/watch?v=_HFMrYUH-Ig&t=1637s
A couple things that were nice was the inclusion of a new o-ring for the mating surface between the master cylinder and the booster and the tougher finish on the booster itself.
Final impressions are a good product for the price and definitely worth the work, pedal feels good and it fit properly.
Imgur album of the booster and old o-ring.
http://imgur.com/a/apA4D
#3 · (Edited)
Junkyard booster is a BAD idea, the youngest booster is 10 years old, they can fail as early as year 12.
For reference a new ATE brake booster was around $175 last I checked.
For anyone that runs across this thread, here is what I put together a few years ago - http://forum.e46fanatics.com/showthread.php?t=1057387
The car I replaced the booster on 2 years ago was 2001, I see your car is a 2002. Not sure the build dates, but the 2001 I replaced the booster on spent most of its life in stop and go traffic and we get very hot here in the summer. So 12-14 years is looking like the typical lifespan of the power brake boosters depending on where the car resides and how it is typically used.
This problem is already out there, some people have identified the problem, some haven't and some of the boosters have not failed yet.
We will see these power brake booster failures more and more in the near future as these cars continue to age.
And to Jake's question, the booster is metal, I believe steel.
#7 ·
Haha, I'm never doing this more than twice. I should also mention that there is warranty on the A-1 but it is voided if your Master Cylinder is leaking when you install it. If someone does end up ordering one all relevant info is on the box and packaging.
Sent from my SM-G925V using E46Fanatics mobile app
#9 ·
I'm not seeing the "A-1" booster on RockAuto, which one do you think is the best bang for the buck out of any of them?
I stay away from RockAuto. Too many bad reviews of poor customer service.
Don’t bother with off-brand parts for anything important, like brakes. Stick to the quality ones. The OE booster is only $141 at fcpeuro with free shipping and a lifetime warranty.
#10 ·
Purchased a Cardone 54-73141 brake booster. Had a professional mechanic install it. During the test drive, it was noted that the brakes were always applied. Could not get the vehicle over 60 MPH. The engine was racing at 4000 RPM. Brake pads started to burn. Got back to the garage and could not touch the wheel axles due to the heat. Purchased a different booster from a local source. (This one works just fine) Compared the original, the local sourced and the Cardone booster. The Cardone booster rod extended 1/4 of an inch further than the other two. (That explains the brakes always applied) I would avoid anything by Cardone in the future as it appears they have no Quality Control.
