I have 2 fault codes on my 200 328i (115K miles). P0441 - Evaporative Emission Control System Malfunction
Purge flow valve and P1580 - Throtte Valve Mechanically Stuck. Also under the Inspection/Maint monitor the following come up as "not ready": Catalyst, Heated Catalyst, Evap System, Sec Air, 02 Sensor, and H02 Sensor.
The car is in limp mode (EML light) and resetting the codes and turning the ignition on/off does not appear to correct the problem. Could i have a bad catalytic converter? What would the symptoms of that be? I have not ever had the O2 sensors replaced? What about the Mass Air Flow sensor? Any thoughts and suggestions would be greatly appreciated. Thanks!
