Radiator Mounting Bracket Removal?
7.1K views 2 replies 2 participants last post by  pauly99
#1 ·
Chasing a leak but I was more than happy to do a cooling system refresh. Thought it was the expansion tank so I replaced the expansion tank, hoses, water pump, water pump pulley, thermostat, fan switch, etc... last weekend. Leak seemed to be coming from right around the radiator plug so I replaced that as well. Still leaking. I've decided to replace the radiator today.
So I've removed the shroud/fan, hoses, transmission cooler (bought new o-rings), and expansion tank. I've also removed the torx screw on the drivers side about 90% of the way up on the mounting bracket. The radiator can push out but it looks like it is still attached to two hoses on the drivers side (one of them being the power steering hose). Do these hoses need to be removed or is there something else I need to remove or push away on the mounting bracket to not have these two hoses attached as I attempt to take out the radiator?
#3 ·
Thank you. I did figure it out myself after a while but glad you confirmed for others. I removed the radiator, installed the transmission cooler with new o-rings, radiator, and then expansion tank with a new transmission thermostat. I've run into a problem now in that my automatic transmission car has a radiator drain plug which has wings on it. I turned it slightly too much and broke off those wings when putting in the new drain plug. Arghhhhhh.
There is a torx screw near the top of the radiator on the drivers side. You cannot see it unless you look under the radiator support above.
Move the radiator back, then lift it out.
