Hi guys,
Looking for some advice/a sanity check on an overhaul I'm planning, specifically around less commonly discussed pulleys. Car is an '03 (07/2002) 330i auto m sport.
Lost the idler pulley and threw both belts 20m into a journey, luckily it was -4C so temp gauge barely hit 10 O'Clock. There was no warning or sound, I suppose there have been some squeaks in the past. Attached a vid/pic below.
Here's what's planned so far:
1. Everything in the fcpeuro mango overhaul kit
2. Idler pulley + dust cover, both (mechanical) tensioners, water pump pulley,
3. Power steering pulley for good measure
4. Pusher fan delete - have a Mahle electric fan enroute to replace my auto fan(s)
5. Plenty BMW coolant + distilled water
Questions:
1. Anything I've missed?
2. I ordered the power steering pump pulley for good measure, does that make sense?
3. Is the idler pulley fail suspicious? Anything else to check?
4. Any damage to look out for?
5. I'll check the alternator pulley can be hand-spun, but regardless should I change it? Is it as easy as the rest? Should the alternator be changed?
6. Crankshaft, a/c pulleys - these seem expensive/trickier but what's the deal on them? What should dictate them being changed?
7. Planning to do the coolant temp gauge scale mod and set up an alarm, anything else?
Questions:
