Are BMW bolt threads something different than metric fine or metric course? I need to replace one of the four small bolts that holds the aluminum differential support bracket to the bottom of the car (as opposed to the two big bolts that also attach that bracket to the car). I took one of the other three bolts to the hardware store and used a thread matching template that they have. I think this bolt fit into the 8mm hole, but can't remember if it was course or fine. In any case, it threaded nicely through one of the holes in the template so I bought four bolts of that dimension. But when I try to install those bolts, it is obvious that they don't fit right. So are BMW bolt threads different than hardware store fine or course? That part number is 33326760345. Btw, the reason I bought 4 is because I would like to replace all 4 with slightly longer bolts. If anyone knows of a BMW bolt of the same dimensions but 5 mm longer, please let me know.
As for part numbers, these are fiddly parts for which I cannot find part numbers at RealOEM. If anyone can help me out, I would really appreciate it:
1. The self-tapping screws that hold the long heat shield you have to remove to remove the exhaust (not the flat-ended ones that also hold the braces).
2. The small plastic clip that holds the wire on the brake wear sensor and that is located on top of each rear trailing arm.
3. The plastic clip that is often broken when removing the rear seat bolsters. I broke the one on the right.
Thanks!
Thanks!
