Parasitic draw - Fuse No. 41 (Radio)
1 reading
15K views 11 replies 3 participants last post by  SSchwab
#1 · (Edited)
Boys,
After a lot of frustration, non-starting, and a lot of reading on these forums, I came to the conclusion after a number of tests that I have a parasitic draw; the culprit being the radio (fuse 41)
Big thanks to you guys over in this thread:
http://forum.e46fanatics.com/showthread.php?t=861679
At the moment, I have fuse 41 pulled and everything is working and starting as it should (sans the radio obv).
How do I get my radio back up and working? The thread above doesn't say much how to fix this other than I may need to 'jump the fuse' or 'relocate it to another slot.'
I was hoping for some guidance in the most simplest terms possible. I'm neither saavy in the automotive and electronic arts, and have limited resources to play with, but am determined to fix this.
A little about my car: 2003 BMW 325i 4-door sedan. As basic as it gets through and through, no modifications, with the sole exception of an aux cable modification to the radio I installed some 6 years ago.
Cheers!
M_a_
#4 ·
My radio is always off. I don't typically use my radio often, only when on long(er) drives, and before turning off/leaving the car, I always turn the radio off.
Something must have happened in the last two months (possibly a short?), but I don't know what
At the moment, fuse 41 is still pulled out till I figure out how to fix it
#6 ·
This is what I thought, but I dont know how to fix it
In the thread I quoted above, I recall someone writing to either (1) jump the fuse or (2) relocate it to another slot in the fuse box
I dont know what either of these two mean and how to do it. I'm hoping someone can advise
#11 ·
Thank you; I'll look into this. Hopefully someone out there has another alternative, but I will keep this in the back of my mind if nothing comes out of it
Pull the radio and inspect the wiring.
And tell us more about you auxillary cable modification.
I will check this weekend, but I don't know what you recommend I look at. It's a pain to remove the trims and remove the radio and I don't have much time aside from weekends. So, please advise what you want me to check.
The mod is really simple - hardly a mod at all. It's a cable that connects to the back of the radio unit and you can just hook up your phone/mp3 player etc. I purchased it directly from BMW and it looks exactly as the one here from amazon
https://www.amazon.com/BMW-82-11-149-389/dp/B000PA00XM
