Good morning everyone,
I wanted to check with you in case you've experienced the same issue. My 320Ci from December 2004 is leaking oil from the oil pan, and I'm not sure whether the leak is coming from the oil pan gasket or the oil filter gasket. I know that when it’s the oil filter gasket, it drips onto the oil pan, but as you can see in the attached photo, there seems to be too much oil residue around the oil pan gasket. What do you think?
Thanks.
Thanks.
