Guys, I solved the problem. There was a crack in the thread of the Vanos hose. The crack was welded, screwed and retightened with RTV and copper washers. I did a pressure test before reinstalling. now smooth and dry, no leakage. I have worked on this subject so much that I am now a professional. I was mentally exhausted doing this. I'm tired of saying here or here.
my recommendations. If there is a leak, the first thing you should look for is the temperature sensors and the vanos hose inlet. Second, is the surface smooth? Other than these, there is no other reason to leak. The oil leak here is pretty deceiving. It is necessary to be absolutely sure of the leak area. I used a camera for this.
First of all, I think the original ofh production is faulty. Because the seal grooves are too deep, they cannot be fully compressed. secondly, when the return valve is plastic it wears out. it would be easier if this was an e36 or e90.
my ofh had a lot of trouble as it was repaired by a newbie before. The first surface is slightly curved. Even 0.05 mm of curvature is effective, as the grooves I mentioned earlier are deep. second, holes 1 and 4 weren't very good. I actually solved this with a long m8 8x125. Then a friend of mine who makes helicoil helped me. We made Helicoil because it is stronger. then the surface was smoothed on the machine. plugged in and now dry. I couldn't find a new one so I tried to fix it. If something like this happens to you, replace it with a new one, it will be easier. Thank you everyone for your help. If you have anything to ask, I'm always here. Sorry for the translation mistakes
