141 - 160 of 217 Posts
I picked up a piece of granite from a local stone guy. Off cut from a job.
I got emery cloth (220) from Harbor Freight.
questions:
1. Do I use any spray adhesive to keep the emery cloth from slipping?
2. Wet or dry?
I do such dry.
Super Moderator
2003 330cic, 2003 325iT
Discussion Starter · #142 ·
Ok, I gave it a shot. Would love feedback on what I got wrong!
Emery cloth:
928597
Mounted to stone using 3M photo spray adhesive:
928602
Sanded using a combination of up and down and circular motions with only enough pressure to counteract the lopsided shape and weight distribution:
And the finished surface:
928600
Super Moderator
Discussion Starter · #143 ·
Problem.
When I was installing the OFHG the upper right bolt spun as I was torquing it and removed the threads from the block:
928607
So what is the smart move here?
Super Moderator
Discussion Starter · #148 · (Edited)
Back on track! Got my timesert kit and made short work of the oil filter housing.
928931
I also got all of the camshaft tools, so I am putting the cam to cam chain on. Sadly, the used tensioner I bought was the wrong part, so another delay. Ugh.
Next week...
928882
Super Moderator
Discussion Starter · #149 ·
And the M56 intake:
928932
If anyone is curious, there are a few salient differences:
1. The manifold gasket is different, and seems MUCH more durable. The old one was still very soft and flexible
2. The flange in the center is for the evap valve, which is stainless. The connector is much more robust.
3. The smaller black connector below it goes to the sucking jet pump. On the M54, this is a simple hose connection with a clamp. On this manifold it is a removable connector similar to those on the CCV of the M54 and uses silicon tubing
4. The air distribution piece is welded on - so no o-ring and no leaks
5. There is no hole for the intake air temp sensor, so no leak there
6. No CCV connections - the CCV is in the valve cover - no leaks...
7. No large vacuum connector.
8. It uses a modified 330 throttle, and a 330 DISA, boots, and MAF
9. The base of the manifold has no bracket. it is held solely by the studs on the block
928933
Super Moderator
Discussion Starter · #150 ·
Doing some starter rebuilding - may as well while I wait for parts ;)
Before:
After:
New pinion and commutator bearing/bushings, new brushes, new through-bolts, cleaned, tested, and re-greased
Super Moderator
Discussion Starter · #152 ·
A little more progress this weekend. The camshaft chain is in with a new tensioner, and the VANOS is snug in place:
929409
Not exactly sure how to get the crap off the thermostat mounting surface. Another "fix it with gasket sealer" special. Argh.
Something you may want to do looking at the photos. Push in and rotate the non return valve so the fin that is wearing starts somewhere new and doesn't trash the OFH. Snip from your photo below with red circle.
929410
//Binary is in my DNA
2002 BMW 325i
Straight car pron Archbid
Might I suggest a correct amount of Curil T?
Super Moderator
Discussion Starter · #158 ·
Super Moderator
Discussion Starter · #160 ·
So I scored a pair of ZHP camshafts from an 04 330i that seem to be in great shape:
929617
Groove on exhaust side journal cylinder 5. Otherwise all smooth.
929618
Now the question. If I am opening it up again, should I bite the bullet and rebuild - new head gasket, new rings, new rod bearings. Already have both seals replaced as well as intake, valve cover, timing chain and oil pan gaskets.
Pro:
  • I dislike that my other b30 requires such effort to stop oil burning (Rotella, o2pilot, frequent dipstick checks)
  • I could pm improved Mahle rings and (maybe?) look forward to 200k miles with less stress
  • Engine is on a stand and not getting installed until August at the earliest
  • Another notch in my mechanic's belt ;)
Con:
  • Can't figure out whether I have to timesert or not (no overheating, 98k miles)
  • Never done it before
  • Money - I estimate $300 for head work at machine shop + $5-600 for gasket, bolts, rings and bearings, timeserts $150
Please weigh in if you have an informed opinion (or if you have a ZHP exhaust sitting around unused)
