MAF Sensor Test
83K views 23 replies 14 participants last post by  captkhaos
#1 ·
Does anyone have a DIY for testing a MAF sensor in a 2000 BMW 3232i? I have very poor acceleration with this car and believe this may be the problem.
#5 ·
I have had poor acceleration for a couple months, and it finally and consistantly kicked out the following codes yesterday...
- P1397 cam shaft position sensor.
- P0101 mass or volume air flow circuit range performance problem.
I replaced the exhaust side cam position sensor and cleared the codes...no new codes have appeared.
The reason for suspeting a bad MAF is that I got a P0101, and when I disconnect the MAF, my 0-60 time decreases by 2 secs. I am not rushing to the dealership to spend $300 for a MAF because I haven't come across an article where a defective MAF will cause acceleration problems; it idles fine and is not misfiring.
Please let me know if I should be looking at something else.
David
#8 ·
simple yet effective test....
If it is a bad MAF you will most likely have a shitty idle....
Test for a bad MAF: Unplug it, drive around for a bit and see if the car performs better. If it does, bad MAF. If not, then there's another problem...
And before the thousands of don't do that it'll F^ your car post come in. Your car runs off of redundant systems. A.K.A. it is designed to run off of the map sensor in the event the MAF fails. I wouldn't recommend leaving it unplugged for more than just this simple test but that's because a bad MAF is better then no MAF
#17 ·
My method may not be the best most technical way to do it. But most people don't have acesses to the equipment needed to run a ful diagnostics. You may not like this method, you may not think it will work. That is not my problem. I have used it on two cars, with sucsess of diagnosing a failing MAF. However, I will state that these cars were dealing with rough idles as well as other factors. When the maf was unpluged and the car was cranked it idled fine. Plugging the maf back in yeilded a bad idle again. Thus, the maf was the problem.
I'm not trying to say that this is the best or only way to check a MAF but, for the average enthusiast, this is the only method I know of rather than paying a shop.
Finally, if my method is so wrong or useless why have you not posted the correct way. I don't doubt your skills as a mechanic i simply ponder upon the fact that you say I'm wrong yet provide no evidence of why. True I have provided no evidence that it will work other than past experience but the OP can test my method and yield a result (whether possitive or negative). However, you negate my solution and offer no path in return. simply is seem to be leading towards action where you seem to state do nothing.
#18 ·
I know I've already posted why your "method" is completely wrong. All you had to do was search through Seth's threads to find the correct way to test a MAF:
http://forum.e46fanatics.com/showthread.php?t=617788
#23 ·
Hello JBEurotech,
I see many responses where the MAF sensor fails and car keeps on running/driving. I just had a MAF sensor fail, and the accelerator pedal was disabled. 02 Manual 330CI. Car stays in idle and it will not let you rev up the engine.
Why some BMW allow it to continue running and others do not?
#24 ·
