Status
Not open for further replies.
MAF readings at idle?
1 reading
40K views 10 replies 7 participants last post by  majestic707707
#1 · (Edited)
Hi,
So I am a bit confused here. I have seen some information that MAF readings should be about 3.6 g/s, however in other places I have seen it is supposed to be around 5 g/s.
In this video https://youtu.be/_smyH_WI6Xg , he says that his MAF was reading too low (about 3.5), and triggered his p0171 and p0174 codes, and replacing his MAF solved his issues and brought the values up to 6 to 8 g/s. However I have also read that 3.6 is the approximate value we should be seeing.
I have been dealing with codes p0171, p0174, p1085, p1083, p1351, p0306, and p1349, and so I am trying to clear up this confusion.
Any advice would be appreciated, thanks!
Edit:
My car is a 2002 330i
#2 · (Edited)
5 g/s is too high. Forget about most of what you have found on the Interwebs, as I recall someone once told me EVERYTHING on the Interwebs is correct an 100% true, for some reason I kind of doubt this.
There are many variables as to what the baseline MAF reading should be and also under what conditions the measurement is obtained. Most of these engines have a NO LOAD Warm Idle MAF reading of between 3.6-4.2 g/s. After looking at the YouTube video you posted, note that the Engine Idle was 850-900 RPM when he was was taking the readings but also note the Calculated Engine Load at 22% which is double what the value should be, so either the car was in "Drive" and/or the MAF is reading too high at idle because the Calculated Engine Load should be around 10% with a proper MAF value in Park/Neutral at warm idle. The YouTube star many have paid close to $200 for a counterfeit MAF and he may not even realize it!!!
But under many circumstances the MAF is ruled a problem and under many circumstances the MAF is replaced with a cheap or counterfeit Asian MAF from eBay, Amazon, the local auto parts store of even ending up with a counterfeit MAF from a name brand supplier. The ONLY MAF that should go on these cars is a Siemens/VDO MAF from a reliable source like FCPEuro, OEMBimmerParts, ECSTuning or a small handful of other sources. Even these may not guarantee 100% non counterfeit parts, but they have a good history of having genuine products.
But before you jump all over the MAF as the source of your problems, you need to obtain more data. Warm idle Fuel Trim and MAF readings. Freeze Frame data and if need be generate Log info for review.
If you have not seen and read this link, you need to read the first post at least 3 times before you do anything: Solve your misfires, lean codes, rough idle - https://forum.e46fanatics.com/showthread.php?t=897616
You also should get the OBDFusion App as it has all the capabilities that are needed to resolve most driveability problems. One of the most cost effective Apps available.
If you need more info, search my user name and the term OBDFusion, you will find more than you care to.
#7 · (Edited)
YOU MUST check the box to Auto Save Diagnostic Report. Can be found Settings, General, all the way to the bottom of the display Diagnostics, Auto Store Diagnostic Report, make sure to "check" the box.
FYI: on my iPad, it appears under Settings, Preferences, General, Auto Store Diagnostic Reports.
#11 ·
I compared a 20-year-old original Siemens MAF with recently produced VDO, Hella, and Delphi MAFs under identical conditions. Hella turned out to be garbage, and I tested two VDO units, both showing high readings of around 16 kg/h during hot idle. On the other hand, the Delphi unit provided a normal reading of about 14.4 kg/h. It seems that modern VDO MAFs have issues with sensor sensitivity or calibration.
Status
You have insufficient privileges to reply here.
