For me, my E46 seems to have the most heat insulated engine bay of all the cars I have owned by now.
Considering the fact an engine is more efficient if it can reduce heat loss, I probably understand why it has been designed in such a way + it is not quite a small engine.
However, I would like to ask other owners if this is typical for an M54. For example, cars with electric fans usually run it, after engine shutdown, for a while, to dissipate heat. My E46 does not do that and, on warm weather days, even after 2-3 hours, you can feel the heat all around the front of the car, like it has been running until then.
Or, perhaps, I have a problem with my electric fan although, I have no running problems, no abnormal coolant temperature etc.
I was thinking to try removing the hood insulation, to increase the heat exchange rate, and to install it only during winter, as such heat levels may have negative effects on many components, especially electronics, within the engine bay.
Of course, as long as they design it like this, I presume they knew what they were doing but, it would be really helpful to know if other E46 have this in common.
