2.9K views 2 replies 2 participants last post by  Alexanderay
#1 ·
Hello everyone,
Around two months ago my headgasket blew on my bmw so i decided its finally time for a full engine rebuild. Im really open to anything at this point, my goal is to build this engine (m52tub28) fully na and be pushing 300+. Just for clarification the engine is completely torn down to just the crank and block so i want to replace anything and everything that can and should be done.
Ive read about swapping m54b30 ( crank, pistons, rods) and maybe different cams (no clue which ones) but would like to hear what you guys would recommend to do as well as what else should be replaced(seals, gaskets, sensors, internals, etc) while my engine is completely torn down
#2 ·
It's pretty hard to get extra HP out of the M52 /M54 engine without going with a turbo or supercharger.
You can put an M54 crank and ZHP or Shrick (I think) cams in your M52tu, and the larger M54B30 intake but you will struggle to get it tuned right in your '99328i.
My suggestion is to get the M52tu engine as stock as possible and leave it alone. Replace front and rear suspension on your 328i, get it's interior and exterior looking good and drive it like you stole it.
Unless your M52tu consumed oil, I would not replace piston rings. I know I recommended this in your other thread, but I thought you had an M54, which has a worse piston ring design than the M52tu..
I would in your case:
1. get the head fixed/valves tested by a machinist
2. time-sert the block
3. clean everything.
4. replace cooling pipes (OEM only)
5. replace timing chain guides
6. loctite or wire the oil pump nut
7. replace vanos seals and maybe the rattle rings
8. New front and rear main seals.
#3 ·
