Jerk when shifting from neutral to drive
1 reading
40K views 35 replies 18 participants last post by  WDE46
#1 ·
Has anybody encountered this problem before? When I start up the car everything is fine. After about a 1 hour drive, when I shift from neutral to drive I feel a violent jerk as the gears engage. This also happens from N to reverse. After the car is shut off and allowed to sit, the problem goes away but comes back after a long drive. I don't feel any slipping though when driving the car.
#2 ·
There is no load on the drivetrain when in N. You select either R or D, and the transmission puts a load on the drivetrain. You should feel something when this happens.
Do you feel something abnormal? It's difficult to say. You should visit a mechanic or talk to a friend that knows about these things. Just from what you said, I don't understand what you think the problem is. I suppose the problem for me is that I cannot judge what "violent," means.
#4 ·
I can't speak specifically about the BMW transmission, but on some other cars, your exact symptoms result from one of the solenoids getting "sticky." The cure on those cars is to replace the assembly of four or five solenoids. I think that on the BMWs, it may be possible to replace individual solenoids.
#21 ·
Not necessarily. Maybe a fluid replacement to start with? Hydro fluid can deteriorate or become air saturated affecting servo function thus affecting band pressure. It has been many years since I had an auto transmissision and I recall a similar problem. It was on a 3L V6 Ford Granada. On that particular box you could adjust the bands by means of an adjustment screw at the bottom of the housing. All you had to do was tighten it up to a spec torque and back it off half a turn. That sorted it out for me on that occasion. The converter can cause jerky responses as well. I would look at fluids first before writing it off.
#34 · (Edited)
I'm with JJR on this one. I'm confused about whether you have a manual or an auto. If you have an auto, it really is bad practice to shift into neutral all the time, and I wouldn't be surprised if it accelerated the demise of your transmission. If you have a manual, then good for you. It is smart to pull the car into neutral when coming to or at a stop. This relieves the throw out bearing from doing unnecessary work.
As for your noise/jerk, jack up the rear of your car and inspect items in this order; (1) Rear differential bushing (2) Driveshaft guibo/flexdisc. Report back. If either of these items get bad enough. They can turn a slight bump into a loud thud or jerk. It all depends on their condition. Sure it could be your trans, but why start there when it takes maybe 10 minutes to check these items?
