Hi everyone,
I just picked up a 3-ton low-profile floor jack and a pair of 3-ton jack stands. In addition, I ordered some BMW jack pad "adapters" that fit nicely into the E46's designated jack points.
This is my first time jacking up a vehicle by myself and I am working in my small two-car garage with limited space. I can jack up one corner at a time easily, and tested the jack and jacked high enough to get one wheel off the ground. I then lowered it back down.
I have yet to place the vehicle down on a jack stand as I am waiting for the jack pad adapter to arrive (on the 28th).
My main purpose is to be able to take the wheels off (one at a time, if need be) for cleaning and inspection (as well as checking/cleaning/inspection of brakes and suspension components).
Being that this is my first time, and taking everything mentioned above in mind: is it safe to jack up one corner, let's say rear left, and place the jack stand in the front left corner. Or is it necessary to use two jack stands (to avoid stressing the vehicle body)? If so, how can I achieve that (again, limited space in garage and driveway is sloped)?
I have read about jacking from the rear differential brace, but there is no room in my garage for that, and I have read posts from some that the four designated jack points are the only appropriate spots for jacking/lifting the vehicle.
Thanks in advance!
Thanks in advance!
