Status
Not open for further replies.
HVAC Relocation Hack
28K views 20 replies 10 participants last post by  325ciLover
#1 ·
Does anyone have instructions on how to do the relocation of the A/C unit without purchasing the kit? $80 seems steep for this piece.
#2 ·
the HVAC control will wedge in there just fine, it just leaves a little gap. You can do it and decide later if you want to order the new part.
#7 ·
It isnt really loose...it presses in there quite tightly in fact, you likely wouldnt notice the gap unless you were looking for it, its maybe 1/8".... Try it, if it bothers you, spend the $45-$85.
#11 · (Edited)
Yep.....I used a little bit of foam weatherstriping to make mine sit at the right angle and hold the unit "down" so that all of my "gap" is at the top, it took a couple tries to get it right but hhhmmmm...can you see it?
By the way, thats a mic on the upper left of the HVAC unit...I was playing around with mic locations for the bluetooth.
Thats a pretty good comparison there between the OEM and the Dynavin's appearance....
#12 ·
Yup when i put mine in i just pushed mine in until the hvac kit arrived, To be honest unless you were really looking you would not know if the kit was in there or not.
I just put the kit in because i am pedantic about **** like that. The kit just has the bottom rounded corners to fit in with the bottom of the controls and that's about it.
#19 ·
Okay, the HVAC move rack I ordered referenced above got here today. I didn't realize it when I ordered it that the seller was in Poland so it took a little extra time to get here. It seems to be a sturdy, quality piece. I won't know about fitment and what it looks like when installed until I do so and it's still a little too cold here in mid Michigan for that.
Status
You have insufficient privileges to reply here.
