I bought my car with a non functional efan. I figured the final stage was busted and ordered a total of 3 new fans thinking I had been incredibly unlucky with DOAs.
The fans worked on a known good car, so it's an issue upstream of the fan on my car.
I have 12v to the proper pins in the connector, and I do get some voltage from the signal wire.
My next step is to test the signal wire for continuity issues. Problem is, I've had a hell of a time finding a MS43 pinout which indicates the efan pwm signal wire.
Can anyone direct me to a pinout with the pwm location, or which pin in the connector I should be testing?
If it checks out, I have another MS43 on the shelf I can swap in to rule out a DME issue.
Sent from my XT1563 using E46Fanatics mobile app
