Help ! Sluggish . Disa valve ?
1.8K views 15 replies 5 participants last post by  WDE46
#1 ·
I did my upper and lower intake boots along with vacunm hoses leading off the upper boot . Also replaced valve cover gasket and fuel filter . My car is still sluggish when accelerating and throwing codes p1349, 1351 and 1353 help what could it be ? Runs ok for a little bit after I delete them . Slight bucking .. Vanos seal had been done btw Could it be disa or throttle body ?
Sent from my HTC One using E46Fanatics mobile app
#7 ·
A VDO fuel pump is About $150 and easy to change, consider a fuel filter at the same time, mine was about $60+. Pull the disa out and inspect it, the flapper broke off the bell crank on mine and threw codes before it started misfiring. I got lucky and only lost a little of the plastic, the pin was still there but it had backed out just a little. Even if it's not causing your issues I'd inspect yours and consider the German American Solutions rebuild kit. $78 is worth the piece of mind about losing that pin into the intake manifold.
#11 ·
Here are the codes from my peake reader
E3 O2 sensor adaption cyl 1-3
E4 O2 sensor adaption cyl 4-6
EE misfire cyl 1
EF misfire cyl 2
FO misfire cyl 3
F1 misfire cyl 4
F2 misfire cyl 5
I used my cheap OBDII reader and got lean codes and some O2 sensor codes too but didn't write them down.
#13 ·
Was the misfiring happening before the valve cover gasket? If not, did you hook up the ignition coil grounds properly? There are two.
If I looked up the codes correctly, then you have 4, 5, 6 misfiring which is a whole bank. Strange that the other bank (1, 2, 3) wouldn't misfire as well if it were something like fuel delivery or a vacuum leak. You have no lean codes??
A DISA shouldn't cause symptoms this bad. Usually they just leak a cause a lean code.
