ok so i have a 2000 323i, manual trans... just replaced...
- expansion tank AND cap
- T Stat
- water pump
- Aux fan
- radiator
The car has never done this but yeaterday i was driving home from VA and 2 hours into the drive the car started heating up!!!!! temp almost got to red... I pulled over, poped the hood and coolant was spewing from under the radiator tank!!!! Let it cool, and drive to the park and ride...
Today i replaced the cap and e.t. drove the car after putting more coolant in it and about an hour into driving it overheated again!!!! This time it was while i was pulling into my house, still spweing coolant from new cap!!!
So i checked the fan, and it seems it only works on low speed while the A/C is on!!!!! however now todayif i was moving it would cool back down, but when i would stop it would heat up again!
soooooo do you think it is a temp sensor on the lower rad hose that sends thie signal to the fan???? Or maybe a faulty new fan???? or what else???? There is no oil in coolant, smells or smoke from exhaust!!!!
- T Stat
- water pump
- Aux fan
- radiator
