fuel pressure test/adapter for fuel rail schrader valve
9.8K views 24 replies 10 participants last post by  kburger
#1 ·
Hey fanatics, kburger once again. 751,000 miles on the 2000 323ci. It's been quite an adventure to say the least. Anyone have a part number or link to a fuel pressure tester, current!, that will work on the e46 fuel rail schrader valve to do a pressure test. All threads have links to harbor freight test kits that are not in stock. And why doesnt anyone carry an adapter for that fuel rail port? I bought a harbor freight master test kit years ago only to discover now nothing in there fits it.
Thanks,
Kburger
#2 ·
I bought this one several years ago -
#5 ·
Believe it or donut, a permanent gauge is a major failure point-
look up Bourdon tube gauge, and you'll see why. That tube is brass...
I have had to make up one using parts scrounged from the local
friendly bike shop's scrap parts pile- the cheap pumps have a short
screw- on hose that works really well mated to a small 100 psi gauge.
And yes, the Horror Fright sets don't all have it. D'oh.
t
#7 ·
Kudos to pointing this out.
Building my own and customer track cars. I love information (sensors/gauges) also love redundancy. However any system must NOT be a point of issue or potential failure. (See the guy with a direct wire ahmeter into the cockpit)
Most often the best for any such is a well placed sensor with it's mating gauge mounted inside. Albeit fuel pressure sensing is risky.
We now return you to your normally scheduled program.....
#14 ·
ok extremely frustrated here. Here are two pictures. One is shrader valve with cap next to it. second picture is the second fuel pressure kit i have purchased. There is no fitting that will work. it needs to depress the tiny valve inside the shrader valve. Any help is appreciated.
kburger
