Hi all,
Can anyone tell me which relay under the hood is the fuel injector relay?
Thanks!!
Thanks!!
The injector relay is the one labeled as ignitionHere's what I found online.
It does, but very slow via the ring gaps/ring lands.When soaking the top of the piston, how does the liquid, in my case BG EPR, not deep down into the bottom end?
You purge the fuel pressure using the schrader valve on the fuel rail.even with the fuel pump relay removed, there will still be pressure in the fuel system
