The vehicle is a 2002 330ci automatic with 130000 original miles.
The car came from an auction so I don't have any previous information. The car runs rough (has a misfire) and CEL. I plug in my scanner and after the automatic detection process tells me my specific model, it starts to connect with the ECU and loses connection. The scanner is a Bosch OBD 1200, I have never had a connection issue with any of the other 30+ vehicles I have scanned with it (so please don't get hung up on this). The pins inside of the the scanner are not bent. Pins 4,5,7,15 and 16 look to be in good shape on the BMWs OBD port under the dash. I am aware that there is a BMW exclusive port inside the compartment where the ECU resides, however I don't know anybody with a GT1, ISTA, Autologic, Launch X431 or Baum Tool DS2021.
Under a load the idle is worse
No abnormal smoke
No weird knocking
I have read forums where people suggest disconnecting the battery overnight to try and reset the ECU, I've tried that.
Everything appears to be plugged in properly to the ECU and other sensors in the driver side motor compartment. No shorted wires or wires that have been cut.
MY QUESTIONS: Is there the technology out there that will allow me to reprogram a donor ECU so that it mirrors my VIN? Or are they a rip off? Do I need to give in and buy a $1900 ECU from BMW because each computer is "VIN specific"? I am confused as to what replacing the DME vs the ECU does, what are their different functions? Is there a test that can be done to verify that it is a computer issue? PLEASE elaborate my fellow car enthusiasts! Many thanks in advance!
No abnormal smoke
No weird knocking
