Diy supercharger time - Eaton m62 on m54b30
65K views 22 replies 14 participants last post by  Landlorder
#1 ·
Several people have added the Eaton m62 to their bmws in europe. We have many eaton m62's available here in UK so ive ordered one for £200 off a merc slk230 kompressor. This should be fun. Never really worked with metal before. I only want 6psi and won't be using an intercooler. Only jobs I will outsource is the cutting of brackets (maybe) and welding of pipework/flanges as I've never welded before. And of course tuning (been recommended 2 options in the uk). Hyde Motor Works from new zealand has given me the confidence to make this happen. He has created a kit using a toyota sc14 and is in the process of making brackets for the m62/m90. I too can design brackets and put them onto 2d cad files. The flanges should not be difficult to make - one of them needs to be shaped from about 76mm round to oval for the intake on supercharger. The other one looks easy to do with a small plate with hole and welded on outtake Pipe. The part number for this eaton m62 supercharger used in mercedes slk 230 and maybe others is A1110900380 with a short snout. This is the one that can fit the e46 and e36 and probably many more.
I am at 200k miles on my 2003 330ci facelift and upto date on all maintenance. The only mod I have a 3.38 lsd. My car is a 6 speed manual. No codes and running like a champ. Yes I do go through oil at about 1litre per month easily and have been so for quite a few years now. Hoping the oil catch can helps here when I install the charger otherwise it is probably my piston rings.
So just waiting for it to arrive and getting ready to just "stand over the hood for ages to figure it out". Excited.
This supercharger has a clutch. I'm not placing it where the ac is so can't use that plug so where do I wire it to safely to be always on with ignition? I would love to have an on off switch as well with 2 fuel maps but I doubt that will be possible within budget.
This really should not be too difficult to do. Will keep all posted.
#2 · (Edited)
If you choose to tune via the MS43 tools that Daniel and others here have created (get ready, it is an extremely long thread full of vast amounts of information: http://forum.e46fanatics.com/showthread.php?t=1082287), you could possibly wire the clutch to an unused DME output and have your OEM DME control it. Another way of enabling/disabling the supercharger is to run a vacuum activated bypass valve. I've used this personally in the past and it is extremely effective.
#4 ·
Thanks for the tuning info, I have been going through that thread and may give it a shot with another used ecu. Alot of information out there. I got the supercharger and am now just waiting for delivery of some steel plates and some intake pipe to custom make the flanges. See image below for flange design, managed to trace it off the supercharger.
#5 ·
My Bosch professional jigsaw goes through 6mm mild steel, all be it slowly, without problem. Just used it. No need for plasma cutting. I think I am going to attach a bracket onto the 2 alternator bolt holes with longer bolts. If anyone thinks this is not a good idea do say. Bits and pieces are coming in and I am trying not to be wasteful.
Been looking at bypass valves too - will probably be going with part number 06A145710P. My throttle body is after the supercharger so will need it. As for the electro magnetic clutch we can cross that bridge when it comes to it.
Ps. I am on a drink driving ban so what better way to spend it than this. Build needs to be done by April 2018 when I get my licence back :) Also got 2 little kids to look after so progress will be slow ish.
#6 · (Edited)
Hi im also using hyde's brackets to fit the Toyota sc14 to my M52TU. What a learning curve! Its very enjoyable and i cant wait to get it all up and running. Been gathering bits and researching the hell out of what needs to be done to make it as reliable as possible. I will be cooling mine. Looking into water to air cooling ( a charge cooler) to reduce psi loss. Yes more expensive but all my research and advice from hyde himself is to cool if i can.
Wish you luck , be interesting to read if to decide to post your progress. Im also here in the uk
Sent from my [device_name] using E46Fanatics mobile app
#9 ·
Hoping thats not the case as I've seen the m62 installed on e36 328's. Thought 330 will be ok. Im not looking for big boost. Also the m90 eaton is more expensive and harder to get hold of. Still will be going ahead with this. If someone knows how to work it out and show what pulley size is needed for x amount of boost it would be helpful.
#10 · (Edited)
If you use inlet flow calculation even the m90 is small.
A small example for inlet flow calculation:
engine displacement x max rpm x 0,5 (once every 2rpm air is sucked in) x fill ratio (85-90%) x pressure ratio (5psi = (14,7+5)/14,7=1,34
So:
3L x 6500rpm x 0,5 x 0,85 x 1.34 = 11105L/min (or 11,1m³/min or 666 m³/hr)
And this is with a fairly low 5psi boost, and a non optimized flow in/out the cylinders (so no extra cams, headers, large plenum etc etfd)
So where are those points on the compressormaps:
see the red dot
M62:
M90:
You can see that even with the m90 it starts to loose efficiency in the top rpm, but say on half throttle, you'll be in the optimum range. And there is some room for higher boost, up to say 7-8psi no problem.
But you can clearly see that the m90 is a far better match.
And to go a bit further:
if you take for example a lysholm 1600ax that is used in for example ESS kits, you get this: (the red dot is for the above calculation, the blue one for the TS2+ calculation):
You can see that the 1600ax is too powerful for low boost (and performs better at medium/high boost, say 8psi and above), although if you look at the efficiency range, the red dot still has a comparable efficiency as where it is on the m90 chart ;) )
If anyone thinks these calculations are off or not quite correct, like using more correction factors, I'd like to hear :)
#13 ·
Ebay , but search US listings, they are dime-a-dozen (150-350 USD) commonly used on the GM 3.8 FWD pontiacs buicks, olds, etc so if you see a 3800 supercharger, that's the eaton M90 available in at least 5 generations going back to late 1980's.
  • Like
Reactions: ctlikon
#17 ·
As has been pointed out, M90 came on 3.8l (231) GM for decades, across Pontiac, Buick, Chevy brands. It went through several upgrades (5 generations?) and there was a very healthy aftermarket supporting them due to the size of the install base. I used to have an NA Firebird 3.8, and did some cursory research that direction long ago. The L67 engine code (FI version of the 3800 Series 2 and 3 as opposed to L36) Pontiac M90 had a longer snout, but I believe a few of the snouts swapped directly. If you are looking in a yard, you want LaCrosse, Monte Carlo, Park Avenue, or Grand Prix GTP. All of those were in production with blowers into the mid 2000s and were still getting upgrades and refinements, although some of that was in intercoolers that wedged between the blower case and the intake manifold, and wouldn't be useful to M54 folks. All of those motors were FWD transverse mount, for what it is worth.
https://zzperformance.com/ was big on that scene, and they still carry parts, including ported cases. If you can get an M90 to work, they are cheap, plentiful, oem reliable and still supported if you know where to look. I want one on my X5.
#20 ·
Looking forward to seeing the progress. I wanted to go turbo, but this being a second car I can source together a DIY kit like this.
Plans are to take a GM 3800 S/C and get it to work. Land, do you have the prints or specs by chance? I have 2 friends who do CNC and I would like to make the brackets.
