Status
Not open for further replies.
DIY: Code used MK60 ABS/DSC using NCS Expert
16K views 0 replies 1 participant last post by  Bali
#1 ·
Follow this guide to install the BMW Standard Tools software, which includes NCS Expert.
The attached guide (see attached file below) walks you through coding a used Bosch 5.7 ABS module for an E39, but the process is the same for E46.
The steps are the same, except the following:
  • Step #5: choose E46 instead of E39
  • Step #6: choose KMB (pre-09/2001) or AKMB (09/2001+) instead of IKE
  • Step #9: choose DSC instead of ASC5
After you are done you likely will need to reset the steering angle. Follow this guide for that.
Status
You have insufficient privileges to reply here.
