DIS v44 Coding
16K views 20 replies 7 participants last post by  hughfr4nc15
#1 · (Edited)
Hello,
I have a 318i E46 M43 built in 12/98, it has both 16 and 20 pin ports.
I have bought the following cable (has a white board inside) and adapter (connects pin8 back to pin7):
I have installed:
EDIABAS 6.4.3
INPA 3.0.1 (according to F1)
DIS v44
I installed everything according to this and this threads and also DIS_v44_&_v57_Installation_Check.pdf.
The APItest is successful...
I used the DOS tool to set the cable to 100 Kbit's K-CAN. Is this correct?
My problem is that I am able to see the engine errors in INPA and in DIS but I'm not able to access other modules for diagnose or coding in DIS v44.
For example, I'm trying to retrofit the BC and I've already replaced the stalk.
Following this guide when I choose retrofit and it tries to read from the car, it throws an error asking "is the ignition on? battery has enough power?" something like that... and I can't go any further.
When I try to diagnose other modules in DIS I get this:
Can you guys help me understand this? Anyone else with this cable?
Since my car has both 16 and 20 pin port should I be using that (20) one?
Ask whatever you need to help me solve this and I'll try to provide the info.
Cheers.
#14 · (Edited)
I can confirm that with the 20 pin adapter I was able to activate my BC! Thanks for that.
Now i have another issue...
I'm trying to activate some Car Memory functions like Visual Acknowledgement When Locking/Unlocking, Auto-Locking, Recirculated Air Memory, etc... but when I reach the screen below I'm not able to get passed it... no matter what I do it keeps showing that screen. I've tried to turn ignition off/on and then press YES, I tried it with the ignition off, with the key in the 1 position... no success...
Can someone help?
#19 ·
Just to confirm that with the 20 pin adapter I was able to activate everything I wanted using DIS and NCS Expert.
Here's what I coded/changed:
- OBC Active;
- Climate Control shows LO and HI instead of 16Âş (C) and 32Âş (C);
- Pressing unlock once unlocks driver's door, twice unlocks all doors;
- Automatic central locking after X Km/h;
- Automatic central locking is re-locked after 2m if the car is unlocked but no door is opened;
- Visual acknowledgement when Locking/Unlocking;
- Changed Oil Service from 25000Kms to 15000Kms (I do it every 15k so...);
- Fog lights also turn ON with "Follow Me Home";
/me is happy! Thanks guys! :thumbup:
Any question just let me know.
