Hello,
so I’ve had my E46 325CI for around 10 months and had to get the MOT, it failed on “structural damage”, the last MOT must have been dodgy or something as there’s no previous mention of this.
On both sides where the rear brake pipe and hose connects to each other and is mounted to the car has corroded, one brake bracket has come off completely. There are holes where it was connected and idk if someone has an easy fix for this as it looks like rear subframe, diff, exhaust, prop, petrol tank and likely rear suspension parts will have to be removed to properly weld it up, otherwise your welding next to your gas tank which isn’t great as there isn’t room to protect the tank & weld.
I’ll add photos but any tips or advice is helpful!!!
