Hi, was wondering if anybody had a solution for water cooling top mount turbos. I currently have my top mount taking coolant off a "T" in the bottom radiator hose, and returning coolant via the bock drain. However, the turbo is higher than the coolant fill on the expansion tank.
I try to "Burp" the system by bleeding the turbo of air via cracking the fitting bolts while I blow down into the expansion tank, which pushes fluid into the cooling system, forcing the air up high out the cracked fitting bolts. However, I think air is still pocketing up in the turbo while I drive. I'm not certain, and my way of bleeding the coolant isn't scientific at all, but I was wondering how people get around this. What I do could do nothing, I have no idea
I haven't had any heat problems yet
I came across a swirl pot on a drift car, supposedly helps combat this by being higher up than the turbo. Anybody use this?
Any other solutions?
