All, before you dismiss this, please hear me out. I am trying to replace my brake light bulbs and it's "clearly" a 1157 bulb right? well, it is not so simple. All the 1157 I have found so far the pegs/pins on the side are straight (180 degrees) but mine needs that at 150 degrees. See the picture.... I have found before that my 330ci (production 09/2000) has a lot of weird stuff. For example, my chrome exhaust tips are welded on so I can't change the tips easily, etc. If you have any idea what this bulb is and how I can get an LED version it would be great... again, all the 1157 replacements I have found the pins are straight across but mine is at an angle. Thanks for the help
I am having the same issue, except I've got 1156 bulbs, not 1157's and the same offset 7225 bulb you show here. I have not been able to find an led replacement that fits either, still trying. I've got a 2002 325ci vert w/sport pkg production date 01/02.
