Does anyone know why BMW specs so much negative camber in the rear of the e46 (-2 degrees)? Is there something inherent in the suspension design that needs more neg. camber or is it just to promote more grip in rear?
I am autocrossing a mostly-stock e46 and trying to determine the best alignment. I don't have camber plates in front so max negative camber I can get is around 1 degree. Normally, I'd want the rear camber to be the same or less than the front but the OEM spec is -2 degrees. I am considering trying -1 degree camber in the rear but am wondering if there is a reason for the higher spec.
And please no flames or "don't deviate from the spec, BMW knows best" nonsense. I am autocrossing and tracking and doing other things BMW didn't plan when they set the spec and I am willing to try something different, accept lower tire life, etc. I just want to make my car handle as well as it can without putting more parts on (at least not for now). TIA.
