Big problems after doing clutch
11K views 30 replies 9 participants last post by  SOMT
#1 ·
Hi looking for some help here, ive just done the clutch on my car but the car is running like s**t now... got myself a scanner and getting loads of codes... dont think all this could go wrong at the same time could it? or is it one thing thats wrong and thats setting off the rest of the codes?
Car was running fine before - ive replaced the vanno rubber washers,plugs and ventalation stuff etc about a month ago
attached scanner results... thanks guys and girls
# ERRORS IN UNITS
Unit BMWTNR HW SW-FSW ERRORS / SHADOW-MEMORY
DME* -> 7.508.292 10 6.x.x 7 errors
EWS -> 6.905.666 03 08 no errors
ABS* -> 6.759.073 04 0.0.91 3 errors
A/C -> 6.919.784 30 11 no errors
SRS -> 6.912.755 10 32 no errors / 2 errors
IKE -> 6.915.259 21 31 1 error
LCM -> 6.919.828 16 30 no errors / no errors
ZKE -> 6.914.362 11 20 no errors / no errors
MFL -> 0.000.000 01 10 no data
PDC -> 6.921.415 01 17 no errors
RAD -> 6.900.402 50 42 no errors
VTC1* -> 7.516.207 10 6.x.x no data
SMF -> 8.263.136 07 0B no errors
# ERRORS DETAILS - DTC(hex)/PARAM(hex)
DME* -> 2858/62 - VVT-Teaching function at stop
285E/E1 - VVT-Control unit internal failure
2782/64 - Camshaft sensor outlet
278E/61 - Diff. pressure sensor suction tube
2731/62 - Camshaft control inlet
27BB/62 - Camshaft control outlet-VANOS0
2783/01 - Hot film air mass meter
ABS* -> 5D93/A0 - Wheel speed sensor front left start recognition v_comparison.
5D91/A0 - Wheel speed sensor front left extrapolation.
5E16/20 - CAN Timeout instrument cluster
SRS -> Shadow-memory:
70/10 - Seat occupancy detector, connection to B+
03/40 - Passenger's belt tensioner, resistance too high
IKE -> BF/58 - Internal fault, EEPROM checksum 1 (BMW-section), coding incorrect/incomplete
# SCAN END
#4 ·
Make sure you've plugged everything in. But, that you did all this a month ago and now you're running into issues suggests that something new is wrong...or maybe you just didn't plug something in firmly (or it lost its clip) and it's fallen loose. Start by checking connections on the items you removed to do the work you did. Then start looking for something else.
#10 ·
Yes, the flywheel can go on MANY ways, but there is only one proper way. 6 ways to install the flywheel, only one is correct!
The dowel, or hollow sleeve is often lost or sticks in the original clutch. It is also often left in the crank and if not aligned with the flywheel properly it can be crushed and not be obvious the flywheel was installed wrong.
If the engine runs bad and the lacks a lot of power and the flywheel was removed, my money is the flywheel is installed wrong and the dowel is missing or crushed.
See this diagram, not 100% sure this is your exact year, but they should all be about the same setup.
http://www.realoem.com/bmw/showparts.do?model=AY72&mospid=47632&btnr=11_3187&hg=11&fg=20
#9 ·
Check all connections and wires. The flywheel position sensor could be the culprit.
After you check everything, clear all codes, reset all adaptations, and disconnect the battery for ten minutes.
#14 ·
If you cannot 100% be sure the flywheel was installed on the crank correctly, this this is likely the problem if the car ran fine until the clutch was replaced. If upon the initial start up the car ran bad, then it may be the flywheel alignment and/or the timing cogs may be bent.
Sorry, but this happens quite often and when you have many ways to install a flywheel, the chances are very slim it will be put on properly if you were unaware of the alignment issues.
#17 ·
Hi, i took off the flywheel and it wasn't on right so i fixed that problem and was still running the same so put a new camshaft position sensor on it and its still doing the same... the bmw scanner said it was missfiring on 1 and 3... got a few things cleared on the scanner but still getting this...
any ideas guys? Thanks
#23 ·
The LS swap is referencing swapping a Chevy LS V8 engine into the car.
Man, that looks like a grenade went off inside the bell housing!!
Is the engine/crank still in good shape?
The teeth on the flywheel that the crank sensor monitors are also very critical, bent, broken or missing flywheel teeth can cause problems.
Also is the flywheel from the same type of engine?
Not sure I would get overly excited about the VANOS quite yet, but you mentioned the engine was running bad before the clutch grenaded?
Did your buddy/mate drive this car like he stole it all the time?
#25 · (Edited)
Hi flywheel was bought from ebay and was listed for my car.. how do i check if the crank is ok? tbh ive only ever worked on old escorts and novas etc so im not clued up on this..... car was driven to the extreme i think... i turned up next day and one of the tyres was burst, wouldnt go into gear and the car was running like a pig... :(
no ls swap just a 2lt 318 ci se
#26 ·
You worked Novas and don't know what an LS is? :b: (just bustin' your balls)
The VANOS code you got seems like a somewhat common code on the 318s. You could have an unrelated problem, but as jfoj said, check your flywheel and crank sensor.. all that. Anything could have been damaged from the clutch exploding. If the crank sensor is damaged or bad it may be the root of your car's evil.
#27 ·
Yes, the crank sensor could have taken a hit, but if this car has been beat as hard as it looks, I wonder if other mechanical damage occurred??
How easily does the engine start? Long cranking or does it start easily?
Anyway a 6 cylinder flywheel could fit this engine in case you were sold the wrong part?
Does your flywheel only have a single trigger like this picture?
http://www.ecstuning.com/BMW-E30-318i-M10_1.8L/ES20345/
I know many of the other flywheels have many, many teeth to also detect misfires and these teeth all need to be in good physical shape.
#28 ·
Based on the video it seems like it starts right up, but runs like ****.
I just quickly Google searched the VANOS code and it came up for a bunch of people with the 2L motor. Only difference is they got the codes under different circumstances. Any chance that it's unrelated? Based on the looks of that clutch I would think some other damaged occurred, especially with all those small metal pieces rattling around in there at high speed.
#29 · (Edited)
